Wanted to temporarily Remove the Rear Plastic Cap on both sides of Luggage Rails ? , so I can take off the CrossRail
anyone know how this can come off. I tried to pry , little comes apart , but seems to be attached / screwed somewhere
- thx, Rich D.
Start with the right-hand rail (passenger side) and pry at the right side. It should move. Pull it off with your hand. Do the same on the left (drivers) side, prying on the left side. Pull it off.
If that does not work, come back again.
You need to pop off the back roof rack cover gently without scratching the car. I suggest a plastic trim removal tool to do this or a small tiny flat head jewlery screwdriver. Loosen the crossbar screws and then slide them off to the back.
Here is a thread with the cover off. (see post #20 )
