1 - 12 of 12 Posts
Anyone have any insight on the best way to remove the blue underlay on the rear Toyota badge?
I think it looks tacky and want it gone before I black out the emblem.
Thanks!
Usually the inset coloring on car badges is a plastic film overlay. See if you can carefully lift up one edge. If it lifts up you can just peel it off.
looks to me like the badge needs to come off to access the film that’s under it. What I’m looking for specifically is if there are posts, screws, etc securing the badge or if some fishing line will pop it off.
Discussion Starter #8
Managed to remove the emblem. It has two posts, both the emblem and the blue underlay have an adhesive back to them. I recommend getting a new non hybrid emblem to replace it with for the cleanest look.
146090
Discussion Starter #10
Did you manage to replace it cleanly? How do the posts work?
yes it came off fine and I found a replacement emblem with pre applied adhesive on eBay for 15$, the posts are just posts that go into two holes, no retaining qualities at all, just for alignment.
1 - 12 of 12 Posts
