Hi Everyone,
I would like to know are the relays for the rav a toyota specific part or are there aftermarket ones available that fit with the right specifications ?
Another question has anyone had problems with the lamp failure unit at the rear of the vehicle....awhile ago my brake lights stopped working ...I checked all the normal causes & couldn't find the problem, eventually i traced it back to the lamp failure unit , inside the unit some of the circut board was damaged .. i patched it up & have the brake lights working again , however the warning light on the dash is on all the time saying i have a failed bulb .. i am wondering whether to replace the unit or try and remove it all together seeing as it caused the brake lights to stop in the first place .. any suggestions .
thanks
for your input in advance
Austin
To get the right relay that just plugs in then Toyota is the best answer, but others may fit.
I know my 99 Rav4 has at least 3 different types of relays that don't interchange.
I had a Camry with a bulb failure warning light but my US model Rav4 does not have such a system.
The one I had also checked the tail lights, do you have any other lights out?
you probably already solved but sometimes if you disconnect your battery and fit it off again those warning lights go away... i had a car that the oxygen sensor failed and even after I fixed it the light was aways there... then I did the battery thing and it was all good, never again
I usually get relays at salvage yards, I usually can get all the relays and fuses off a car for $10 or less. If I'm buying other things they often just let me have them for free. I keep a static free bag with a couple of each size/amperage in my glove box for emergencies.
