Hi all. I have a 2000 model year rav4 with 4x4 and manual, produced in december 1999. I have noticed that TC001-01 does not apply to my model year, but.. I'm getting the 5th gear popout anyway. There is no shuddering in 5th gear as described by many members.. and sometimes it will stay in, at slow speeds. Once the RPMs and load % is up at higher speeds, i see the gear shift lever moving the more i push the accelerator. So.. my gear shift popout seems to be related to load. The motor mounts are clearly worn... has anyone ever replaced them and saw the 5th gear popout go away?
If the motor-mounts are worn, then you might want to replace them anyway.
Here is a newer TSB that includes your 2000 model.
Reactions: neptronix
Cool, thank you. I am going to try the motor mounts anyway before doing the hard job! Do you know if this is an up to date parts list? I've gone through this forum and found plenty of parts lists.. not sure which is correct.
