1 - 1 of 1 Posts
Kevin40g has reported a post.
Reason:
Post: Towing capacity
Forum: 4.3 Exterior
Assigned Moderators: N/A
Posted by: ST-Bob
Original Content:
Now that the 2016 hybrid Rav4 is out, there's some question about its towing capacity with the Toyota hitch. Some things in favor of raising the towing capacity are:
* No torque converter or clutches in the Hybrid Synergy Drive system
* Standard anti-sway system built into the traction control/vehicle stability control system
* Higher net HP than the standard I4 (Up to 194 HP from the conventional 176)
* Dynamic braking from the electric motors to reduce load on conventional friction brakes
* Additional vehicle weight over conventional powertrain (especially at rear axle)
* No additional battery capacity, charging capacity, starting capacity or cooling capacity required for hybrid - it's already built in
So what do you say? I'd say the standard I4's 1500 pound capacity could be safely increased to 1750 or maybe even 2000 pounds. Sound about right?
1 - 1 of 1 Posts
