1 - 2 of 2 Posts
rdgrimes has reported a post.
Reason:
wrong forum
Post: Bosy Side Mouldings
Forum: 4.4 Electric RAV4 Hybrid & EV
Assigned Moderators: N/A
Posted by: piratefan
Original Content:
Yesterday I installed body side mouldings on my 2015 Rav4. After reading the instructions I was really fearful of screwing up the install . The instructions have the measurements in millameters which I converted to inches. What I finally figured out was the measurements are not as critical as the instructions portray. If you use common sense and get the measurements close on the front door and use a straight edge to line up the rear moulding with the front door the install will look great. Left side following the instructions to a tee took two hours. Rt side using the straight edge took ten minutes.
Some of the instructions measurements: I could not find a tape that measures in mm so I converted mm to inches.
83mm= 3.27 inch
350mm= 13.78 inch
7.8mm=.307 inch.
These measurments are absurd. How do you measure .307 of an inch?
I taped the mouldings in place, lined them up and installed. Look great.
1 - 2 of 2 Posts
