M
hi all, there was a post on this site about resetting the engine light, a sort of DIY job, but as much as i have looked, in all the sections, I can not find it.....anyone else remember it ? , if so can you direct me to the post........thank you..
M
Discussion Starter #2
oh dear, it was not on this site afterall, Just found it..so here it is if anyone else wants it..
Turn ignition to the on position, depress the odometer selection button until it reads the total mileage. Then turn ignition off, whilst in off position depress odo button again, whilst maintaining button depressed turn ignition to the on position, the mileage will then change to read ------, then count down to -, then 000000, then back to the driven mileage. The light should then be extinguished
That's how you turn off the maintenance req'd light, not a check engine light.
Way to shut off a CEL is with a OBD reader or to disconnect the negative terminal on your battery for a few minutes.
M
nouse4aname
I now realize that the heading was wrong on my first post, :roll:
I will get the hang of it one day......... :D
