Are any of the Metra TOYUSB ports compatible with the 2013+ Rav? Has anyone who installed an aftermarket stereo been able to keep the original USB port and connected it to the radio?
The Metra Axxess TOYUSB says 2012 Rav4 but know one has an answer to weather they have made it work for 2013.
Thanks
Have you attempted to try any of those Metra axxess toyusb adapters? I purchased both and am going to give it to the installer to see if they will work I have not read anything about customers even trying to use it considering the plugs in the back of the factory stereo are identical.
It will probably work. All it's doing is going from a Toyota-specific plug to a standard USB.
I mistakenly thought you were trying to replace the plug you alread had.
On second thought. I'm not so sure about the AUX mini jack. That may go dead unless there's another plg for that coming off of the factory USB harness.
