1 - 13 of 13 Posts
Been looking around but seems not to be much info for the 2009 Australian version oem satnav headunit that the ZR6 has.Has anyone got info on the wiring/pin setup needed to install an aftermarket reverse camera? It's the PZQ60-00200 unit with 26028 on the front panel.
One picture is the back of a unit that has the same plug configuration, the other pic I'm holding the head unit.
Cheers, Wes.
Hi,
I just replaced the OEM unit on my RAV4 and I see the same type of connector on your unit. The reverse camera plugs into the square grey socket bottom right in your first picture. (Big white socket above and blue to the right of it) I have not yet worked out what type of connector it uses but I suspect it may be glass fibre?
As each of the sockets are different sizes if you have the connector kit you can only connect them one way.
Regards,
Taffy
Hi there
I am looking for some help i just put this unit in my hilux has any one bought a camera and harness to suit this head unit?
Thanks in advance
reverse camera input to PZQ60-00200
Hi Wes,
Did you get any replies.
The socket that Taffy talked about is the sat nav arial socket.
I need to know what pin in the blue six pin socket is video in for the reverse camera.
Cheers
Toyota can't help and auto electric now searching but just need to know whereally the rca plug wires can go into .had lots of bad info just want to finish job .dash in pieces waiting. Please please please can someone help. Thanks.
I've finally got it. I ran a green trigger wire from left side under kick plate scuttle red with gold spots to red out wire on camera rca lead. Then coming out of head unit joined white and black wires = cam negative and negative into black rca shield and then yellow to rca centre or positive camera . All works if in turned on and put into reverse. Yes. I have got pics that may help.
That's a very nice RAV4! It looks even better with the steering wheel on the correct side: :cool:
144412
Hey I've been trying to figure out how to keep my original reverse camera when putting an after market head unit in my Toyota aurion. Funny thing is I have the exact same Prado head unit in my car as the pictures you have. And similar cables And I'm pretty sure what you've explained will work with mine. I'm just unsure which RCA cable to buy? I' have a Sony xav68bt head unit with steering wheel control harness and the steering wheel patch lead etc. Just need the camera to work. It would be much appreciated if your able to help.. cheers
1 - 13 of 13 Posts
