Hi all,
Through further research with the OEM Navigation unit found in 2009 to 2011 Rav4s (E7019 on the bottom right corner of the faceplate)... I have found that you can integrate a reverse camera into the navigation display though proper wiring into the existing connectors.
By inserting the following signals on the following pins, the navigation display will switch to the reverse camera display when the vehicle is shifted into reverse.
You will need to insert a 12v+ signal onto pin 5 of the 5-pin connector (Connector E82 - Part # 90980-11909)
Remember the picture is looking at the connectors from the front view (the end of the connector that goes into the radio)
Pin 1 = Parking Brake Signal
Pin 3 = VSS Signal
Pin 5 = Reverse 12v+ Signal
On your 20-pin connector (Connector E89 - Part # 90980-12460) ... you need to insert the following connections into the connector
Pin 11 = V+
Pin 12 = V-
Pin 13 = CA+
Pin 14 = CGND
For Reference the following pins are the other connections already in the connector:
Pin 3 = VSS Signal
Pin 6 = SWG - for Steering Wheel Control
Pin 7 = SW1 - for Steering Wheel Control
Pin 8 = SW2 - for Steering Wheel Control
Pin 15 = ARI - for Stereo Jack Input
Pin 16 = ASGN - for Stereo Jack Input
Pin 17 = ALI - for Stereo Jack Input
Pin 18 = AGND - for Stereo Jack Input
Pin 19 = AUXI - for Stereo Jack Input
I used an aftermarket camera made by Eclipse (Fujitsi-Ten) - Model # BEC-108 ... however any of the BEC series BEC-104 through BEC-108 will wire-up the same way:
V+ = Eclipse Yellow Wire
V- = Eclipse White Wire
CA+ = Eclipse Red Wire
CGND = Eclipse Black Wire
You do not need to do anything to the navigation unit itself for this to work ... just wire it up, throw the car in reverse, and the image is displayed on the screen ... shift out of reverse, and you are brought back to the previous screen (MAP, Audio, etc.)
Pin 3 = VSS Signal
Pin 11 = V+
Pin 12 = V-
Pin 13 = CA+
Pin 14 = CGND
Pin 3 = VSS Signal
