Okay... I've been studying the PW wiring diagram you sent, and comparing it to the basic fuse/relay box - def / location diagram I sent you. You are right, on the real wiring diagram it does show PW relays! They are just not labled or shown on the other diagrams. I've been comparing the two to try to get a grasp on which is what and where. I am not afraid to buy new relays... if I can find an identical other relay to swap and test I will for the meantime. And yeah I hear ya' ultimately you still need the test meter and light - cause it might be the contacts too, not just the relay itself. The only reason I thought the EPS-ECU had something to do with the PW is that I read something while researching the EPS-ECU where it defined its functions and it said PW was one of them? who knows, anyway-
Wiring Issue! Here we go... the plot thickens`
I can't believe I haven't mentioned this before (A MAJOR COINCEDENCE) ... I've just been so overshadowed by the reverse polar incident.
At the exact same time of this whole thing, There was a horrible smell in the car, and I found a dead baby mouse in/on the cabin air filter. And the garage I keep the Rav in did always have a family of rats livin'in it. Its a nice garage I just ignored it. I've trapped them all out since. The rats might have chewed up some wires! It may have nothin' to do with the reverse polar? And remember I never even blew' the 120A fuse link... which is supposed to be the worse case scenario in a rev-polar incident. (unless theres still something to the slow feed of bad energy from a charger) anyway, And after I got the new battery and replaced the two little fuses that did blow... I did drive the car around the yard! and there was nothing wrong with the steering or windows... thats why they are stuck in down position right now.
So I'm pullin around - stop double check everything- a/c - radio -lights-etc. Discover something else just went wrong.. It's in limp mode? all of a sudden, I learn how to fix that... then pull it straight in the garage, leaving the windows down because I plan on coming right back and driving it around some more. A couple hrs later I go out, get in it, start it up... all warning lights still on? 'that's weird'.. go to put it in gear... it locked? 'thats weird' - stick a screwdriver in it and unlock it, then I back out of the garage--- The Steering is not Working? - oh sh*t!- either are the windows.
That mice chewing up wires has happened to me before (not same garage) I have an old van that I thought the Electronic fuel pump went bad on it, so I drop the tank to replace/fix it... and rats had chewed through all the fuel pump wires above the tank... I taped all the wires back together- the fuel pump was fine.
I'm gettin the test`o meters and light tonight or tomorrow! Thanks for hangin' in there with me!
And I'm gonna keep studing all the diagrams so Im up to speed and start routin` around maybe can find some obvious wire damage ... if I cant thats what testers are for - Yay!
