Roof rail covers
332 7
Does anyone have a part number for or a set they don't need for the roof rail covers that go on after taking off the roof rack cross bars. Mine were lost after going thu a car wash. It's for a 2022 Rav4 Prime.
1 - 8 of 8 Posts
2022 RAV4 Prime XSE (Blueprint)
Looking at mine (which I have in the "storage" bag that came with the cross bars), it looks like:
75631-42010 (RH-F, No. 1)
75632-42010 (LH-F, No. 1)
75633-42010 (RH-R, No. 2)
75634-42010 (LH-R, No. 2)
Guessing RH/LH is right-hand, left-hand, and F/R is front/rear.
Thank you for the info Windracer !!!
2022 RAV4 Prime SE in Midnight Black Metallic
On another note for the cross bars, can they be adjusted so they are mounted further back on the roof? My bars are installed so that the front bar is over the moon roof and I'd like to move them back. We have an Acura roof mount luggage carrier that I want to use with the RAV4 and I will also have to adjust the distance between the bars so that it fits. :unsure:
21 Rav4 Prime SE with a little brother 95 LJ70 diesel
I think the TRD bars from a standard Rav4 fit the same holes in the roof and have more adjustment but it requires a lot of interior disassembly to swap them
Unfortunately, no.
Bummer! I'll have to measure the distance between the cross bars on my Acura and compare that to the distance on the RAV4. I don't think the roof top luggage carrier being over the moonroof would matter but the clamps to lock down the luggage carrier do have a specific range that would have to be similar to the Acura's roof rack dimensions. My guess is that it will work.
1 - 8 of 8 Posts
