No. Drive it. Don’t baby it (let the engine sing some pressure is good for break in). But don’t rag it out either. No panic stops until the break pads seat. Give it some HV mode early with really good chances to warm up. Don’t go a year with 200 miles in the ice. That’s about it. Both my primes were 1k + road trips home. That’s about a perfect break in. The manual is useless for a PHEV.I don't worry about break-in periods too much. On several of my new cars I've gone straight from the dealer to road trips from 500 to 3000 miles and I've never had any problems.
Are the Rav4 Primes any different?
As others have said, you don't need to worry about running in a new Toyota car. Why? Because Toyota runs all engines at the factory before installing them in a vehicle. The fluids used during this period are removed, then replace with new fluids when they are installed in a vehicle. This video shows that engine run test at the factory at about the 11:50 point:Running in ... how did you behave during the running in ?
Thanks for your inputs !
I don't think this is equal to 500 miles or 1000 miles of engine wear, but perhaps I'm wrong. Also, is this the same process in Japan where the Rav4 Primes are made?As others have said, you don't need to worry about running in a new Toyota car. Why? Because Toyota runs all engines at the factory before installing them in a vehicle. The fluids used during this period are removed, then replace with new fluids when they are installed in a vehicle. This video shows that engine run test at the factory at about the 11:50 point:
Yes. ALL Toyota engines, no matter where they are made or for which vehicles, are run at the factory. Have been for years.I don't think this is equal to 500 miles or 1000 miles of engine wear, but perhaps I'm wrong. Also, is this the same process in Japan where the Rav4 Primes are made?
That's what Jeep said when I bought my Gladiator.I've been at Ford and GM Automotive plants. The engines are started for about 5 minutes for ECM programming. Then another 5 minutes on rollers for engine tests. After that it's whatever is needed moving them around for shipping. In total I'd say it's less than 10km worth of engine run time.
Is that why they make a point of describing how to run the car initially, because they're already fully broken in properly?As others have said, you don't need to worry about running in a new Toyota car. Why? Because Toyota runs all engines at the factory before installing them in a vehicle.
260 5-1. Before driving |
●For the first 500 miles (800 km): Do not tow a trailer. ●For the first 600 miles (1000 km): • Do not drive at extremely high speeds.
My point exactly, thanks.Is that why they make a point of describing how to run the car initially, because they're already fully broken in properly?
Breaking in your new Toyota
To extend the life of the vehicle, observing the following precautions is recommended:
●For the first 200 miles (300 km): Avoid sudden stops.
Driving
5
260 5-1. Before driving ●For the first 500 miles (800 km): Do not tow a trailer.
speeds.
- Avoid sudden acceleration.
- Do not drive continuously in low
gears.- Do not drive at a constant speed
for extended periods.
I visited the Kentucky assembly line in 2015. The engines were prefilled with all their fluids before being delivered to the assembly plant.As others have said, you don't need to worry about running in a new Toyota car. Why? Because Toyota runs all engines at the factory before installing them in a vehicle. The fluids used during this period are removed, then replace with new fluids when they are installed in a vehicle. This video shows that engine run test at the factory at about the 11:50 point:
I did on all my Tacomas, and current Jeep Gladiator. I was a tracked vehicle mechanic in the Marines (Vietnam 1969-70), and then an Ordnance Vehicle Maintenance Officer, and before that built and raced stock drag cars. I've always followed or ordered break-in procedures. It's not a hassle. Just don't maintain constant speed for 500 miles. Why? In order to adequately seal the rings to the cylinder walls, deceleration and acceleration accomplishes that. It's pretty simple really. Since many people only keep their cars for about four years, it probably doesn't matter, but I would trust the Toyota engineers before someone here with absolutely no experience beyond "personal experience" or something read on the net. Don't want to follow a simple break-in procedure, go ahead, but don't cry when your vehicle starts using oil prematurely.Seventeen posts on this subject so far and I have a question, actually two.
Does anyone religiously follow the break-in procedure?
Has anyone had an issue attributed to not doing so?
Which can't NOT happen on the Prime or Hybrid drivetrains. If you have a tach you'll see that RPMs are all over the place from zero to higher regardless of speed, even if you get on the highway and set the cruise for hours on end. That's why the manual is useless- it was not written for the Synergy Drive system. It is a cut and paste.It's not a hassle. Just don't maintain constant speed for 500 miles. Why? In order to adequately seal the rings to the cylinder walls, deceleration and acceleration accomplishes that.
