Our 2l EFI Surf (Australian) is only running on two cylinders straight from startup, which to me sounds like "limp" mode, but I'm trying to figure out the cause. I'm going through a tedious process of elimination and I've reached a point where I'm not sure what the next step is. Can anyone help?
So far:
Swapped injectors to see if it was them. Injectors check out OK.
Replaced spark plugs.
Swapped coils around to see if it was them. Coils check out OK.
Replaced ECU (and recoded keys). No improvement.
Can anyone suggest more tests/rule-outs to do??
Any help appreciated.
Matthew P
Brisbane, Australia.
So far:
Matthew P
