1 - 2 of 2 Posts
Hi,
I am installing seat heaters to my 2011 RAV. I have 15A fuse in the fusebox, but couldn't found any point whereto connect power wire. Could you help me with this, pls.
IMA :serious
You either need a "Add-a-circuit" for Low Profile mini fuse. I am assuming that'a what your RAV4 uses.
Or I simply took the fuse that I wanted to use and soldered a wire to it and then crimped my circuit to it.
If your RAV4 fuses are like mine, you already have an un-used slot for SEAT HTR in the fuse box under the steering wheel. I believe the OEM use is 20A but maybe I am wrong.
1 - 2 of 2 Posts
