1 - 10 of 10 Posts
I'm in the process to remove the front bumper cover (cracked it this winter getting out of my driveway) We have the most Interesting winter up here in Canada.. I added a photo of the sensor that is just dangling.
Sent from my LG-D852 using Tapatalk
My guess is the outside air temperature sensor.
Is this relevant to the engine or radiator functionality or only for the outside embiant temperature?
Just the dash gauge most likely. Disconnect it and find out.
Ok, I was afraid it was the airbag sensor that was loose and bouncing all over the place.
I don't think air bags use a remote trigger any more. With the advent of cheap and highly accurate/sensitive accelerometer chips, they are all self-contained nowadays.
Anything SRS related has yellow cable housings.
Which I noticed when replacing the two front wheel bearing, they are perhaps controlled by the abs sensor? A suddent drastic deceleration woukd trigger the airbag? If so, I notice now when I reach 110 kmh (kanadian miles)
The abs and 4wd and the skid light Indicator turn itself on, and to later go off.. And when this happens i have lost the cruise control. Do you think those wheel sensor have a relation with the accelerometer?
The air bag assembly contains an integral dedicated accelerometer. If it were attached to the ABS system I would expect to get an air bag malfunction warning light whenever there is an ABS fault and that is not the case.
Discussion Starter · #10 ·
No you are right, when the issue arrise, I get a C1 414 LH wheel sensor. I was not able to pinpoint this code though.
And as long I don't drive over 110kmh I do think have that issue, And like you mention, the airbag has no code. Well at least I know I won't have an air bag deployed in my face while driving over a puddle.
1 - 10 of 10 Posts
