2021 XLE AWD. Its in for its 10k mile service. I mentioned to the service manager at highway speeds the transmission does not like to go into 8th gear on its own, I often have to engage the cruise and then back off 1mph on the cruise and then it will shift into 8th gear. I have heard that these 8speed transmissions have issues from time to time.
Has anyone experienced similar issues?
Thanks!
2021 Rav 4 XLE gas engine
Thanks!
The issues were in the 2019 and early 2020 models and were corrected by a TSB. The 2021 8 speeds are generally flawless. They are adaptive learning trans. The dealer can blank its memory so it relearns your driving style and adapts to it.
2021 Rav4 LE AWD
I have noticed the same thing with my 21' . However I've noticed it stays in 7th way more on the highway @60mph when the ambient temps are really cold . . It has warmed up significantly over the past few days and I noticed the trans goes into 8th gear like it should . From what I gather many variables have to be met for the ECU to allow 8th gear to engage , engine load , coolant temp , ambient temp , speed , and much more play a factor in which gear it stays in .
