1 - 2 of 2 Posts
2008 Toyota RAV4 V6 Limited
Hey y'all,
I've done a lot of lurking on these forums for repairs and whatnot. I must say you really know your stuff!
While attempting to fix my parking brake I moved the airbag sensor and deployed my side airbags. :crying
I've found a website that will repair the seatbelts and reset the SRS system. I've also found airbags to install.
Is there any specific order to install so I don't set off the new ones?
If there are any relevant posts I missed please send me the link. Still learning the ropes around here for the most part.
Driving a 2008 RAV4 Limited V6
"Help me Obi Wan Kenobi, You're my only hope!"
disconnect battery - wire.
replace the deployed airbag sensors and disconnect the deployed airbag wires,
after that reconnect the battery and TEST the airbag wires with an voltage meter, if no charge is coming on the airbags you know that the sensors are OK.
then again disconnect the battery - wire, wait 60 sec and then reconnect the new airbags.
Reconnect battery wire and use Professional OBD reader that is able to reset the airbags and clean the codes for it.
1 - 2 of 2 Posts
