Hi There
New here but have just bought some after market side steps which will arrive with no fitting instructions. Apparently there is no drilling required to fit them. Is this going to be a simple process for me to fit.
thanks in advance
What brand where they? Where did you get them from? Any pictures?
No drilling, you'd assume the install should be pretty straight forward...
Most of these no drill step install using t-bolts to sucure brackets to the underside. The t-bolt is rectangle piece of steel with bolt welded onto it. The t-bolt then gets inserted into a rectangle hole on underside and turned 90degress, the bracket now bolts to t-bolts and steps bars bolt to the brackets. It will vary from each manufacturer but I have used t-bolts on all with the exception of one.
Sent from my LG-US996 using Tapatalk
