Are the front speaker channel outputs modified or attenuated by the factory, non-JBL radio?
In other words, if the front speaker wires are connected to an aftermarket amp then will the full signal be present?
Or, is signal processing necessary when connecting the front speaker channel outputs to an amplifier?
I know that the rear speaker channels require processing so I'm only concerned with the front channels. Thanks.
Discussion Starter #3 (Edited)
I'm wondering whether to connect the front two channels directly into an aftermarket amplifier that accepts speaker inputs.
Discussion Starter #5 (Edited)
OK, I'll probably use the rear channels from the factory head unit then when creating a 2-channel system since I'm not going to use any rear speakers (no rear fill).
