Hello and Thanks in advance for your help!
I have a 2014 RAV4 LTD w/ tech. Today I was driving up a wet hill (pavement) and the Slip Indicator, AWD, ABS, and Warning (!) lights came on temporarily (for about 60 seconds). They all turned off again once I was over the hill.
Is it normal for the Warning (!) and ABS lights to come on when the vehicle is in AWD mode?
Thanks agian!!
Tim
This thread sounds like the same problem that you experienced, especially since it happened on a wet road. Although the old thread was about a 2006 RAV4 , the principal is the same on your 2014
Thanks Rick. I just checked out that thread and you may be right. It wasn't pouring though so it's a little concerning that sensors could be impacted from water that way.
If there is a problem with the ABS sensor, hopefully it makes itself known soon while the vehicle is still under warranty!
