Was wondering if there is any way to mirror a smartphone onto the screen.
Found a few videos ( cant post video link since i have 0 posts :frown )
But it seems like it would cost around $500.
Would it be worth, seems worth?
or is there any cheaper way to do this.
The short answer:
- Factory Mirroring is not available in latest (14-18) Entune headunits.
- Aftermarket mirroring feed via AV input is not worth.
Solution: replace your headunit.
Why isn't it worth for aftermarket mirroring feed via AV input.
What would be some good head units, was looking at some and they seem to be low quality.
AV Input is analog with low resolution.
To simplify - it is equal if you run a bluray video via VHS.
You will downgrade HD High-Res Screen 1080 x 1920 pixels to an analog composite signal with 480 interlaced lines.
Yes it will work, but will have fuzzy picture, no touchscreen. You will have to hold your phone to operate.
On youtube videos, you saw online, you cannot see the details.
