1 - 2 of 2 Posts
So I have had my rav for about 2 months now. Last night I checked the oil and it was down a full L .... I just had it changed about a month ago and it has been running fine. I cannot see any leaks on the driveway and I watch out my side mirror when I get on it and i dont see smoke!!! Is there any common place that there could be a leak that I am not seeing. Thanks for any help.. Oh yeah 96 4x4 manual
Before you suspect that you are loosing oil, are you sure that enough was put in after your oil change? Maybe it was a simple mistake.
If you are not absolutely sure that enough oil was put in I would just keep an eye on the level. If it does not move, do not worry. If the oil gets very low you will soon know about it. The valves will make a racket!
1 - 2 of 2 Posts
