I installed a 50 Watt solar panel on the roof, work takes me away at times for months at a time and I didn't want the battery to go dead.
I also installed a Pulsetech PowerPulse Battery Maintenance System (amazon.com) to keep my battery in top shape. The system ensures peak battery performance by eliminating the main cause of lead-acid battery problems and failure-sulfation buildup on battery plates.
Photos to follow.
Discussion Starter #2
Parts for the solar panel project:
- 1 ea - HQST 50W Solar Panel 12V 50 Watts Lightweight for Yacht Boat RV Battery Marine (ebay.com)
- 1 ea - HQST 10Amp PWM Smart Charge Controller LCD Display Solar Panel Battery Regulator (ebay.com)
- 1 ea - Mighty Max 12V 500 watt pure sine wave inverter for solar application (ebay.com)
Photos
The solar controller is in the right side rear compartment
That's very cool! Does it work with AGM batteries? I wonder how long it would take to charge up my Chevy Volt? :)
Yes, it works with AGM batteries. I can charge a cell phone or tablet on it as well.
Probably 200 or so years as long as you live in a desert.:shrug:
How did you mount the solar panel on your roof? Is it atop your sunroof?
While I had the headliner out to replace the headliner material, sound deadening material, roof rack, xm radio antenna, and overhead console I installed the panel.
- I carefully measured to center it up
- Drilled 4 holes through the roof where the reinforcing grommets are on the solar panel
- Used black RTV to seal those holes and applied it to the entire back side of the panel
- I put the panel in place squeezing out the air bubbles, this is a flexible solar panel
- Installed 4 stainless steel screws and put RTV on the interior side of the roof as well as all around the screw heads on the top of the roof to ensure a good seal
- Drilled 2 each 1/2" holes for the wiring
- Placed rubber grommets in the holes and pulled the wires through. If I were to do it over I would use a solar cable entry gland for the pass through. I also applied RTV on both sides of the wiring
- Routed the wires to the solar controller and on to the battery.
I don't have a sunroof.
Discussion Starter #7
I labeled the photo that I installed the solar controller in the rear right side compartment, that was my civilian right I guess, it's actually in the rear left side.
