After reading all of the available threads on the web. I went ahead and ordered about $400 worth of product from http://www.secondskinaudio.com
I am going to try to do the entire vehicle and guestimated that I will need the following:
120sf of Damplifier - http://www.secondskinaudio.com/vibration-mat/damplifier.php
90sf of Overkill - http://www.secondskinaudio.com/noise-filter/overkill.php
Tools: spray adhesive for applying the overkill, a grommet removal tool and a wooden roller for applying the damplifier.
The most helpful online document for deciding which products to purchase was - http://www.sounddeadenershowdown.com/
It was the only article I found which put it all together. Having pulled out some of the interior, with the OEM tow hitch wiring install, I guess I feel a little braver.
Personally, I think the road noise on the RAV could be better and after having removed some of the interior, you can see there is a lot of bare metal under the mats with little or no sound proofing. It should make a big difference. The shipping weight of all the supplies is 67lbs. So my guess is that all of this product will add about 50 lbs. My wife doesn't see the need, so likely she will think I am crazy when she sees the entire interior dismanteled.
I was debating getting a cheap $50 radio shack decibel meter to do a before and after, but decided not to waste the money. It will be, what it will be. I will post pictures when done.
Thanks to all that have come before me and posted their success.
