Hi Guys, i am in the process of buying the new NGK Iridium Plugs and Nolofy Wires. Do i need to change the Coil or the Distributer or the Cap? If so is there a performance coil out there? :)
Thanks and CoolRunnings
No, you don't need to change the coil or the Dist. Cap. Their are no performance dist cap either. If you do change the coil, I'd recommend the MSD SS Coil Blaster. Remember you will have to use a longer ignition wire extension, [this is a must do] You will have to weld with plastic to extend your coil ignition middle plug. It is very easy and it can be done with a heat gun. You will also need the Tech adapter from MSD exclusivly for Toyota. Check MSD. I have them, also with the MSD 6A, and of course the Nology Wires. They work well. Some people might say it is unnecessary to install these parts with the OEM electronic ignition. But these people might not know that one thing leads to another. I'd also recommend the Pivot Voltage Stabilizer. This will really help your electrical system. NO stereo sound coming from the engine through the speakers. Better driving lights intensity, Good mide range power.
This is the Pivot Razini Voltage Stabalizer. it's the blue box on the Battery.
You will also need the Pivot Graound kit
http://www.msdignition.com/
http://www.pivotusa.com
Good luck, need any more help. I'll be here. 8)
