I haven't done this particular dash but like most of this era the bulbs should change out, I have read on here that its a common prob so try a search but I'm sure other forum members will be along shortly that have done it to give advice.
Just in case you are enquiring about the dash removal itself you will have to extract the instrument cluster to access the bulb. Some forum members have replaced all the bulbs in the dash with led which looks pretty different. Look in the diy & modifications section on here. Final piece of advice, when you take the cluster out I recommend changing all the bulbs for new ones in the instrument cluster.
