Stains on the window panel and side mirrors?
501 9
Recently took my new RAV4 Prime to the car wash and after drying I found this mysterious stain.
Car Vehicle Motor vehicle Automotive side-view mirror Hood
I tried Goo Gone and All Purpose Cleaner and wiped and wiped for hours with limited success. I almost think it looks worse now. This stain can be found in the side mirrors as well.
Automotive lighting Hood Vehicle Grille Car
Hood Light Automotive lighting Water Automotive design
Do any of you happen to know what this stain may be and how to fix it? If it helps, the car had a small paint repair done a week before, but on the front right bumper, nowhere near the stain. I would appreciate any help :)
1 - 10 of 10 Posts
That looks like car wax residue to me. There also looks to be some overspray on the door panel in the photo of the mirror.
A little fresh wax should soften the hardened old wax and allow you to clean it off before it hardens again.
This is going to sounds nuts (pun intended) but using creamy peanut butter is the best method I’ve found to remove car wax from satin, flat or textured black finishes.
Sent from my iPhone using Tapatalk Pro
A rubber and plastic cleaner with a tooth brush. Or an all purpose cleaner and a toothbrush. Don't let it dry. It could be polish residue from the body shop that was flung onto your car. I have no clue how they got it there. It should clean up easily with the right product.
Looks to me like the passenger side rotating brush got a little too close. Whenever I have had stain/rub damage to the plastic portions of my trim without physical deformation of the plastic itself, rub it with a soft cloth and acetone. It may take some elbow grease also. Go to a different car wash also……
2021 RAV4 XLE Premium Hybrid
Ouch! Never use acetone. It is too aggressive and can actually dissolve some plastics (and the paint). Start with some solvent much less aggressive such as rubbing alcohol. If that doesn't work, go up to mineral spirits, then denatured alcohol. Possibly even lacquer thinner or turpentine.
My bad, your correct. Its mineral spirits. Haven’t had to do it in a few years. Was using acetone to get nail polish off my bathroom tile last week and it must’ve been on my mind.
1 - 10 of 10 Posts
