1 - 2 of 2 Posts
My 2009 RAV4 Limited has an occasional issue with the starter. It has the push button start on it. Sometimes when I start the engine, the starter continues to run after I release the button. It does not do this every time. I have replaced the starter and the starter cut off relay. Still doing it. If anyone has experienced this issue, or knows what is causing it, I would appreciate your help.
Not sure if you are doing this or not.
The start button should be used like that on a computer. Simply press it and release, it may take a fraction of a second but the starter should kick in and start the vehicle. You should not have to hold the button in until the vehicle has started as this may cause the starter to stay going longer than it should.
1 - 2 of 2 Posts
