Is it possible to fix the leakage in the steering rack of i have to buy new. Its 1997 model
Prob need to post in the correct group, this is for 2006-2012 gene group. We dont have hydraulic powered steering.
Your rack seals are leaking meaning you need a new rack. Shop around as prices vary and good deals can be found usually online. Also make sure it is your rack and not your power steering pump or high pressure hose. It is also a good idea you flush your fluid so you are not circulating dirty power steering fluid. This is usually the cause of the seals leaking.
