The SWC wiring diagram is shown below. The 3-wire setup is a resistor network that the OEM radio will recognize depending on which button is pressed. For your Binize headunit, I would connect the yellow wire with the ground wire in the harness, and you can try either the blue or light green wire to the "Key" wire to see if it works.
