Recently flew to Florida for a month and left the RAV outside in the driveway. My neighbor started it up after 2 weeks, didn't move it but let it run for 5 or 10 minutes to top off the battery.
When I came back, I started it up and ran some local errands. As expected, the rotors were rusty but cleaned themselves off after a few stops. I was surprised the tires were flat-spotted as I keep 35-36 lbs in them but that too disappeared in a mile or two.
What puzzled me was the very stiff steering which didn't get back to normal till about 3 days of local driving. I know it's electric with no hydraulics, so what could have caused that? Could the linkage have stiffened up after a month of sitting?
The power steering is mostly utilized at slow speeds, and parking lot maneuvers pull a lot of amperage from the battery. Have your battery load tested at once.
Battery's only 2 yrs old, but probably wouldn't hurt to get it checked, so will do.
The batteries can cause a wide variety of issues, especially intermittent ones. It's surprising to see how many things can be caused by batteries (and not even very old ones!)
Did you drive another make of car while you were in Florida? If so, could be that the power steering had a different feel from that on your RAV and when you began using your RAV again it took some time to get used to it again.
If I drive my wife's CR-V which has hydraulic power steering with a much lighter feel than my RAV's, getting used to the RAV's heavier steering again takes a bit of time.
Ha, funny you mentioned that! I rented a 2017 Hyundai Elantra and yes, it had very light steering. But, the RAV was VERY stiff when I took it out and it has gradually loosened up since. I'm inclined to think lower battery voltage is the culprit. I'll try to find time to take it for a long ride this afternoon, depending on how good the football game is.
