Thanks EINopal. I would like to take your approach. Can you explain a little bit on how you "connected the new line off of the existing illumination circuit"?
where did you tap into it, and how?
Also Thanks ToRayBa
DIY Dan
Sure!
The illumination circuit is where I tapped into. I used 2 posi-taps (these are genius and so much easier on the original factory wiring than the often failure prone, dumb quick splice t-taps) for my positive and negative connections right at the switch! There is an inline fuse (I think a 2 or something like that) off the positive connection.
the negative black wire is connected to the sky blue wire and the red positive wire is connected to a sea foam green wire. That’s it! You’re ready to rock and roar!
I am very new to RAV4world. I come from the 1h8mud, tundras.com, Tacoma world and the products that members frequent there have tended to be the same and not at all common here or at least not that I have seen so far. However, one such source outfit that is seen across all the other sites mentioned is VLED’s...
I like the VLED’s brand for several reasons. They have a great fitment and finish. They feel high end and are BRIGHT! They have proprietary goof-proof connectors that allow for a plethora of connections and install configurations... VLEDS.com
yes this is where I got my wiring from and my grille running lights my interior lights, etc.... All my rigs run em... In fact, I will be adding a second set of super white footwell lights, it is actually a tundra front and rear set, that will come on with the dome light circuits.. Blue is well, uhm, bluetiful for an ambiance but, I like to see when I need to see when I need to see it! So I use the white LEDs for stuff like that, the glove box and center arm rest console!
The Toyota blue oem lights can be purchased pretty much at any Toyota stealership/outlet.
The VLED’s wiring and the oem LED’s connector wire harnesses were married to provide for an easy swap in and swap out of led bulbs, if ever necessary...
Lots more I could answer but I feel that I may have wandered a little here 🤣...
