I swapped the whole tray with an aftermarket wireless charger. It comes with 2 additional usb ports. One normal USB-A and one USB-CI may end up being the guinea pig to pry off the center console panels. Not just for the light, but I want to find a place to hide the USB hub and tap into the cigarette lighter socket power. Since there's only one USB tied to the media console, the manual states you can use a hub to access both a phone (for music/navigation) and a flash drive (for music), but nothing else. So, I bought a 4-port hub and a 12v-5v converter, and it works. It just wastes a bunch of space.
Yes, you can! One of the folks on the forums did it earlier in the year. He posted in either this thread or the footwell lights one. These threads are so long and old now that it is hard to keep track of the useful bits of info scattered in them.I am so pumped I just found this thread! For someone with an LE who would obviously not have the plug or harness for the cubby light, would it be possible to pull power from the circuit for the console backlighting, that way the cubby light comes on and off when you turn on the headlights? Then I could buy the light and the proper harness connector for it?
Hey great post guys definately helping a non handy person like me to do things. I do have to ask, I just got the 3.0 QC charger for the dummy button and there's videos of guys just sliding the wire through and down to the cigarette lighter plug. But they all have LE models and models with the seat warmers buttons and wiring harnesses makes it almost impossible to get that wire through. How did you guys manage to get the trim out with the seat warmers buttons? I tried last night couldn't figure it out. I pull out the 3 tabs in the front but after that couldn't figure out what to do next. To slide that trim loose so I can access behind the wiresHelp! Installed the center light but I can't figure out where this plug goes. It must have come loose when I was pulling out the seat warmer cover. I don't see a spot for it.![]()
Sent from my Pixel 3 using Tapatalk
Edit: oops of course it's for the AC panel above
I am having trouble figuring out where the light is located once the console is back together. Could someone post a picture?Thank you Satavtech for the tutorial. I just did this myself, it was pretty straightforward. I added a couple photos, the first is the plug you use which is wrapped with the white tape over to the right. You can also see the top of the whole for the light.
The second photo is of the light installed and the harness plugged into it.
Thanks! View attachment 146853 View attachment 146854 View attachment 146853 View attachment 146854
Thanks Allyn, this was helpful. I bought the OEM console tray light, but in my 2021 LE, there's no ambient/tray lighting connectors to be found. That "plug to no where" you mention, actually has a purpose in the lower trim versions, it would seem. In my case, this connector runs to the back of a 12v cigarette charger. I spliced in to this, tested the power to make sure it shuts off when the ignition is off (it does, thank god), and ran my wire direct to the light. I find the OEM part is quite dim with full power, so I've opted to not make it dimmable. However, I have pre-mounted a dimmer switch inside my armrest cavity for future tray lighting, as without ambient light connectors, I want the ability to manually set the brightness. I used Blue/Red butt connectors, 18g - 105 Degree rated wiring and loooots of electrical tape to keep everything snug and secure. Due to the missing wiring harness for the OEM light, I used female round pin connectors, flattened to snug up tightly to the square pins in the light housing, and added heat shrink to prevent +/- contact. The light works great, it's a tad dim, but I like the clean factory look.It was very disappointing to learn my 2021 RAV4 XLE Premium didn't merit a lousy blue ambient light in the center storage tray. $30,000 USD and they couldn't even put it in an XLE Premium model - infuriating. Even more disappointing to learn no wiring harness either. (Canadian made, car purchased in Florida.) If it helps anyone, I did find a nice place to get power that is easy access. The back of the center console pulls off easily. Under the USB hub there is a "plug to no where." It literally is an unused cable that terminates into the back of the plastic. See photo. I bought the OEM 81080-42040 as keenly suggested by others in the forum (THANK YOU!) and voilà. I ran wire to the spot above the center tray as detailed earlier in this great forum. To keep things simple, I cut the plug off and soldered in my own connectors. TIP - polarity matters! If you don't have the OEM wiring harness and have to find power elsewhere remember that LED is not like an old fashion light bulb - you must distinguish between positive and negative wires for the LED to glow.
Thanks for the post showing how easy the back of the console is removed.It was very disappointing to learn my 2021 RAV4 XLE Premium didn't merit a lousy blue ambient light in the center storage tray. $30,000 USD and they couldn't even put it in an XLE Premium model - infuriating. Even more disappointing to learn no wiring harness either. (Canadian made, car purchased in Florida.) If it helps anyone, I did find a nice place to get power that is easy access. The back of the center console pulls off easily. Under the USB hub there is a "plug to no where." It literally is an unused cable that terminates into the back of the plastic. See photo. I bought the OEM 81080-42040 as keenly suggested by others in the forum (THANK YOU!) and voilà. I ran wire to the spot above the center tray as detailed earlier in this great forum. To keep things simple, I cut the plug off and soldered in my own connectors. TIP - polarity matters! If you don't have the OEM wiring harness and have to find power elsewhere remember that LED is not like an old fashion light bulb - you must distinguish between positive and negative wires for the LED to glow.
I hope this helps!
View attachment 161915 View attachment 161914 View attachment 161915
Can anyone post photos of the interior lights in the driver's and passengers storage compartment areas. So what the light looks like in which part of the compartment. So a photo from underneath.
I'm in the process of retro fitting the stock lights but those compartments in my rav4 don't have the hole cut outs. However all the plugs and cabling is there.
I think I saw somewhere that the strip is a set with its housing. I'm really not sure how to disconnect that strip or even the light bulb on the driver side cubby but would be nice to take those out a put brighter ones on. The Toyota ones are way too dim in my XSE. I ordered some brighter bulbs from Ali express for the center console and cup holder lights but still waiting for them to arrive so I can swap themthanks for that...yeah that passenger compartment light seems a bit more...I can't find that led strip light in the parts catalogue..unless you have to buy the whole storage console part, which has the led integrated or something.
This was a great idea! I grabbed some 3mm LED's, and ended up doing something similar thanks to your post. In my LE, there's no rear air/con, but instead a little storage cubby, so I installed an LED inside and below. I also installed one for the cupholder as it was bothering me, not being able to see them at night. I also installed the OEM light for the front storage tray. The hotspotting of the blue colour was bother me, as I wanted a more factory diffused glow, rather than intense blasts of light focused on one spot, so I ended up painting the bulbs white with a solvent based car paint. I have the lights on a dimmer as well, as I want all the illumination to match the intensity of the factory stuff to keep it all consistent.Thanks for the post showing how easy the back of the console is removed.
I have a 2020 TRD and it has the USB power cable, but not the additional one for the factory LED. I used your idea to add two 3mm LED's above the USB ports to add ambient lighting to the rear seat area.
I could have easily added a light in the console storage bin as part of this project. I have an organizer tray in the center console and have a light in one of the USB ports. It works well and illuminates both the tray and the area below when the tray is removed. I couldn't find a good location for a light above the storage tray, otherwise I would have put one in above and below it. Thanks again for your idea.
Hi,Can anyone post photos of the interior lights in the driver's and passengers storage compartment areas. So what the light looks like in which part of the compartment. So a photo from underneath.
