Hi all,
I'm concerned about a noise in the engine of my 2023 RAV4. This noise occurs after every cold start, regardless of the outside temperature, and disappears after about 15-20 minutes. It seems like the noise is gradually getting louder.
During the 30,000-kilometer service, I mentioned this issue, but since the engine was warm, they couldn't detect the noise. Initially, I thought the noise was coming from the serpentine belt, so I didn't worry too much about it.
Currently, I'm on vacation in Austria (from the Netherlands, 1100km drive) and have removed the serpentine belt to see if I could identify the problem. Unfortunately, the noise is still present, even without the belt and seems to be coming from the timing chain side near the crankshaft pulley. It sounds mechanical and strangely completely disappears after 15-20 min, only to come back after every cold(ish) start. I’ve recorded it without the serpentine belt mounted:
I've already made an appointment with the local Toyota dealer, but I’d really appreciate any input from you guys. It could be the timing chain, but feels a bit unlikely after just 34.000 km’s. I bought the car new and it’s religiously serviced.
Thanks in advance!
Thanks in advance!
