Recently, I was rotating my four tires. When I went to torques my tires (90lbs.) a stud, from the 30mm Eibach spacer broke. It has McGard Lug Nuts all 4 wheels, M12X1.5 Stock number 64002.
Does anyone know the length of these studs? I have a new set of Toyota studs, but it looks to me there too short. I've tried Googling it to no avail.:confused: BTW, both studs are from the rear tires.
go to your local NAPA and bring the adapter with you,
A good parts guy will figure it out,
The studs are probably press fit, put a lug nut on one and hit it with a hammer, it will fall out the back, you put them back in by running an open ended lug nut down and it will suck it up into place.
The length of the stud is important, but the area where the stud presses into the hub is critical.... proper diameter is a must
You can't just punch out the broken off bit and marry it up to the bit broken off and take measurements? Or like as suggested push out a full stud and measure?
Um.....where did you get the 90 pound torque? My book shows 76 foot pounds.....:confused:
