colombiano11 said:
I was wondering for those with subs in there cars. Do you think that 1 12inch JL sub would be enough to get a good boom or would it be better to just get 2 10inch JLs. Thanks
Since the RAV4 isn't a hatchback, there isn't much between you and the sub itself, so a little will go a long way. If you have the money to spare..go with whatever you can afford, it also depends on what kind of music you listen to.
I'm sort of in the same boat you are with what to get. As far as the box goes...get what sounds best, not what gives you the best space. The bigger the sub the boomier it will sound, with a seal box it will sound tighter, ported a little boomier and open..well then its booming.
I know that tweeter will do everything for you as far as making a box, tuning it to your music tastes, but you're looking to probably spend 200 on the box itself if they make it.
Like was said before you don't need to pull out the stock head unit, but if you do, go with a name brand one, and ask the people at the store what you're looking for. They're usually helpful...if not a little pushy towards more higher end models. Yes say goodbye to your wheel controls, honestly you won't miss them after awhile.
