Has anyone found a Sun Cover for the Navigation Screen?. At certain angles the Sun fades the screen out almost completely.
I have a screen shade in my Prius and like you said it's not a cure all. It helps in most situations but there are times such as low sun coming in the rear window when it still washes out.On my Rav it doesn't have nav and I am glad because I can't see the screen if the sun is out. I seem to get a reflection off my clothes in the screen from sun shining on my clothes. Not sure if a sun screen will provide relief from that. I tried to block sun from the screen but it didn't work. I use a 7 inch Garmin in the center storage area, fits perfect and no issues seeing the screen. Also you can change information even when car is moving.
Thanks i'll look into it. No one seems to be making one that fits.I plan to make my own and here is a suggestion that I will try:
At the craft stores and on the net they sell thin colored foam sheets. I would use black). I was going to buy a black one and cut a strip about 1 or 2" wide. Then I would use thin velcro strips, I'd cut the 1" wide strip in half length wise, to make something about 1/2 or even narrower strips about 1" long. then bond the strips to the edge of the foam pad and the other part of the velcro to the edge of the display. I think with a little experimentation as to the width of the foam that works best for you might be necessary.
So who is going to be the guinea pig?Amazon.com: C-HR-RAV4-Navigation-Sun-Shade-Visor Compatible for Toyota RAV4 2019-2020 GPS Sun Shade Cover Compatible with Toyota C-hr 2016-2020,Anti Glare and Reflection from Navigator Screen: GPS & Navigation
Amazon.com: C-HR-RAV4-Navigation-Sun-Shade-Visor Compatible for Toyota RAV4 2019-2020 GPS Sun Shade Cover Compatible with Toyota C-hr 2016-2020,Anti Glare and Reflection from Navigator Screen: GPS & Navigationwww.amazon.com
I wish it wasn't a stick on as it leaves marks on the screen when and if you remove it. Worried about it flexing from the head. Hope they'll make one that goes over the head unit like a cover.Amazon.com: C-HR-RAV4-Navigation-Sun-Shade-Visor Compatible for Toyota RAV4 2019-2020 GPS Sun Shade Cover Compatible with Toyota C-hr 2016-2020,Anti Glare and Reflection from Navigator Screen: GPS & Navigation
I cleaned the area very well before putting it on. Applied plenty of force and kept it in the shade [garaged] for a few days to go hard. So far so good. It provides plenty of shade for the screen and looks a lot better than the screen jutting up out of the dash.its a sticker base, mine hasn't fallen off (yet). just practice clean surface before adding the sun shade.
mine hasn't warped from the heat, i live in cali ... and it hasn't been that hot yet.
not to be negative, but i've tried this as well and its great if your looking at the screen straight on. from an angle you had dead zone ... just sayingView attachment 159997 View attachment 159998 View attachment 159999
I purchased my shade from Amazon and am happy with the fit and the look. It would be nice if Toyota incorporated a sunshade in the future so we would not have to resort to stick on solutions. Has anyone tried a tablet anti-glare screen protector as an additional measure?
Cost aside, this one appears to fits the head unit much better that the sun shade I purchased. I did not come across the one you found in my previous interned searches. Thanks for sharing.FYI a cheaper option
99.0US $ |For Toyota RAV4 RAV 4 2020 2021 GPS Navigation Screen Light Shield Sunshade Modification Display Shading Plate Anti reflective|Auto Fastener & Clip| - AliExpress
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
