2011 RAV4 Sport V6
My sunroof height was set 1/16" lower than the roof line at the rear by a dealer.
They say they cannot adjust it level with the roof as it is out of adjustment room.
Is there a way to set sunroof height either electrically or mechanically?
Please send me the procedure.
i adjusted the moonroof in my celica and it was held on by 4 torx screws. i'm sure the rav is the same. be sure it's in closed position. then use a proper torx bit with screwdriver handle and NOT a "L" allen wrench. you will strip the screw head using the allen wrench because more torque is needed and an L is not enough. loosen all 4 screws, lift it a little bit, and tighten screws as you go.
some water will always go through. thats why there's gutters and tubes below the moonroof in the pillars to drain the water out.
LOL, hence the reason I don't like sunroofs! Some guy once asked me what a sunroof (or skylight) was. I said what....he said it was a hole in the roof.:D
