1 - 1 of 1 Posts
T
I am selling the following item:
Sunshine Automotive 4W Heavy Wattage wiring system for the H4 or 9006 headlamp set up.
For brightness and safety this uses two heavy power 12V 40A water resistance relays to drive bulbs power more then 400 watts.
For added safety the kit use swiring fuse link and AUTO PLUG IN FUSE for added protection wiring set simultaneously. This kit is perfect if you decided to upgrade to the HID conversion kit.
Heavy Duty Headlight Upgrade Wiring Set for 9006 or H4 Features:
-- Designed to endure high temperatures head lamp connector for high wattages bulbs. So it will work on any high wattage light bulb and won't burnt or melt your harness unlike your original wiring.
-- Heavy Gauge Wiring Set
-- Anti corrosive leap plated treatment to prevention ill-contact.
-- Easy installation and maintenance.
-- Complete wiring diagram in instruction included.
NOTE: the 9006 kit also comes with the 9005 wiring for the high beam. So the 9006 uses 4 headlamp kit.
As always, these are brand new. I am selling the kit at $29.00 each set. Shipping charge is not included yet.
Email me if you have questions.
Here is the link for picture and info.
http://pg.photos.yahoo.com/ph/rav4ray/album?.dir=/f409
1 - 1 of 1 Posts
