1 - 11 of 11 Posts
What do I need to switch from standard to synthetic?
-Drain bucket
-5 quarts?
-New Filter
Any help would be much appreciated.
You didn't complete your profile so we don't know for certain which engine you are referring to, although one could suspect that given the oil weight in your thread title it's a V6. But you will find the quantity answer in your Owner's Manual.
You will need exactly the same thing that you needed for the 5w30 oil changes, except the bottle will say "Synthetic" on it. Mobil-1 is good stuff, generally around $22-$24 at Walmart or Amazon prime for a 5qt jug.
Stay with whatever weight is listed on your oil filler cap... likely 5w30, but possibly 5w20 for a 4.3
If you have moderate to high mileage, I would stick with 5w30. There is only a slight economy benefit to 5w20, at the expense of less protection in high temperatures.
Mine is imprinted on the oil filler cap. :)
Interesting - the oil filler cap on my '11 V6 has the oil weight, but not the quantity. Seems that the quantity would be variable, depending for example on whether the oil filter has been changed.
5-w30 on my cap, 6.5qts written under my hood. That includes the filter because I always change it. Also the miles at each oil change which averages 5,000 miles, same interval I've used on every car I've ever owned. I use 5W-20 since my Hondas do too.
Mobil 1 has a 12 rebate on 5 quart jug until OCT 31, 2017. I got my oil at Walmart and received rebate in 7 weeks. (limit 2)
https://apfco.com/secure/R8235W/
Seriously? This very trollish. Dump the old, change the filter, pour in the new.
Agreed, especially since the OP so far has provided illegitimate specifics.
1 - 11 of 11 Posts
