I have a 2020 Rav4 Limited (gas model) which I bought new in Nov 2019 which I‘ve done some preliminary checks on the battery and the Service Menu is showing 11.2v at rest after overnight in the garage (see attached). This appears to be a depleted battery issue as per the TSB. I‘m not having any of the other issues on the TSB nor described by other 2020 Rav4 owners. I intend to show the local dealership the Service menu output (e.g. 11.2v battery) and suggest they apply the firmware update and DCM reset as you’ve indicated on the .pdf you attached (or other latest version). My questions are to you:
(1) is the T-SB-0089-21 the latest update?
(2) what is the best approach for getting the dealer to apply the updates (e.g. I plan to hand them the TSB and show them a screenshot of the 11.2v displayed on the System screen) and hopefully get a new battery installed.
(3) should I expect them to replace the battery for free (or prorated) or will they try to just charge the existing battery?
(4) is there a way to check the current firmware version on my vehicle? (it has been into the dealership a couple of times for regular maintenance since I purchased it and so it is possible the firmware update and/or DCM reset could have been done at that time?)
Yes that's the latest version of the TSB that I have found. The update file is actually sent directly to the car through it's cellular connection from Toyota's servers, so it's possible the servers may present an even newer version of firmware than is listed in the TSB.
I had my original TSB done at my 5k service. My battery was dead one morning before work and nothing was left on in the car. I was already familiar with the 2020 Rav4 having the issue from this forum. Mine was built on 02/2020 in Japan so I imagine I had a slightly newer version of the firmware from the factory than a lot of the early 2020s had, because for the longest time mine had no issues with the Toyota app or dead battery.
The TSB only covers vehicles under the initial 3/36 warranty. If you are past that I believe the dealership can actually charge you for the fix if they wanted to, although it's such a quick process for them to do while it is in for scheduled maintenance a dealership with a true focus on customer service might do it for free outside warranty.
My battery was not replaced although I have read others on here that the dealership replaced theirs.
The DCM firmware version is unfortunately not a customer facing value like the headunit software version is, to view the DCM software versions you need access to Toyota's Techstream software and a compatible Mini VCI J2534 cable.
If you're a DIY type you can snag an affordable cable on Amazon, and subscribe to Toyota's TIS for 2 days, the 65 dollar plan gives you access to not only the repair manuals, but also the latest version of Techstream and access to all of the various firmware updates and calibrations.
I'd still recommend going through a dealership though, if they screw up the process it is their dime to replace your DCM. 😎
