Introduction:
The purpose of this TSB is to provide updated throttle body part number information for certain vehicles equipped with the 2AZ-FE and 2AZ-FXE engine. The drain pipe has been eliminated on throttle body service parts. Please use the information below when replacing the throttle body assembly.
Download: http://www.rav4world.com/tsb/2010/T-SB-0111-10.pdf
Does anyone know if the computer has to be re-flashed after installing a 3 tube throttle body? I left off the short hose that used to connect to the 4th tube like the TSB said to do and now I'm getting a P0441 code. Not sure if I should go and find a 4 tube throttle body to remedy this code.. Anyone else having this problem?
Never mind, I'm an idiot. After further inspection I see where I did not reconnect the purge valve wires after installing the throttle body. Hopefully this resolves the problem.
