Try flipping them over, i.e. rotate 180 degrees in the socket.
Try flipping them over, i.e. rotate 180 degrees in the socket.I bought these to replace my rear brake lights.
Amazon
The red-brilliant variant.
It works but when I turn the headlights on, the tail lights come on as if the brakes are pressed - including the third tail gate brake light - all at high intensity.
With the headlights off, they function normally. low intensity normally and with the brake pedal pressed - high intensity lights come on.
I did - all four combinations.Try flipping them over, i.e. rotate 180 degrees in the socket.
The 7443 incandescent bulb has two filaments, a 5.9 watt for tail light and an 25 watt for brake or turn signal. The car does not send a lower voltage for the dimmer tail light, rather it sends the normal 12 volt but only to the 5.9 wall filament for the tail light. Thus, your presumption is wrong. The LED versions should have a lower brightness if the correct contact is made.I did - all four combinations.
When the headlights are on, the tail-lights are supposed to be on also. So the car is sending a reduced voltage or current to the bulbs. When the brakes are pressed, sends the full voltage/current - i'm thinking current. But since these are very low current bulbs - they go full brightness at even the lower setting.
These bulbs are 3 watts. The oem sylvania 7443 bulbs are 25 watts.
So looks like most probably resistors that reduce the current are needed.
Just curious as to how it sends voltage to just the 5.9 filament. I only see two wires going into the socket. Of course there could be two wires in each.The car does not send a lower voltage for the dimmer tail light, rather it sends the normal 12 volt but only to the 5.9 wall filament for the tail light.
This may help:Just curious as to how it sends voltage to just the 5.9 filament. I only see two wires going into the socket. Of course there could be two wires in each.
Yes I put in a Sylvania incandescent 7443 bulb and everything is back to normal.
