Hi,
I'm fitting towbar wiring to my 1998 RAV4. Does anybody know the wire colours for the tail light and the brake light at the actual light?
I have green and green/white and need to know which is tail and which is brake
Thanks
On my 99, green for the tail-light, green-blue on for the left turn and green-yellow for the right turn signal, and green-white for the brake.
I would recommend a pre-made wiring harness that you simply plug in such as this https://www.etrailer.com/t1-1998_Toyota_RAV4.htm.
I believe you need that box you see in the diagram for the lights to work properly.
The wiring is as follows for my 99 (I just went out and checked):
Left side (as seen from rear) pull the rear side panel for access. You will be looking for a white connector that is pegged to the body behind the tail lights.
Harness......Vehicle
White.........Ground.............I grounded to the vehicle body
Brown.........Green..............Tail Lights
Yellow.........Green/Yellow....Left Turn & Brake Lights
Red.............Green/White....Backup Lights (yours may or may not have a red wire)
Right side (as seen from rear) pull the rear side panel for access. You will be looking for a white connector that is pegged to the body behind the tail lights.
Green.........Green/Yellow....Right Turn & Brake Lights
I hope this helps
My post above was the color codes at the connectors I mentioned, not at the lamp sockets.
