TSB Number: TC001-01
Bulletin Title: TRANSMISSION ENGAGEMENT IN 5TH GEAR
Release Date: March 23, 2001
Applicable Year(s): 1997-1999 (VIN Specific)
File Size: 94kb PDF
Download: http://rav4world.com/tsb/TC001-01.pdf
Description: New part numbers to improve engagement of 5th gear are provided in this bulletin.
R4W Comments:
G
Wait so this is to repair the issues with the slippin outta gear in 5th and the huge movement when in the gear! Well one day when fifth was moving about an inch and i was in a hurry, the fifth gear shattered, causing me to drive the remaining distance to and from work in fourth at under 75kmh, and this problem is a know TSB?? well thanks toyota for the update, i had the vehicle service by Toyota and they had to replace the tranny with a used tranny because they said they simply couldn't repair it!! Well so im out $1000 bucks for the used tranny and 12 hours of labour running me $3000 into the ground, thanks toyota, last Toyota Ill ever buy!!!!!!!!!, ps. fuel tank neck has completely broken off $2000, air conditioning no longer works, $????, and clutch replacement after only 100,000 km $2000, thanks alot!!!!
33393-12022 Hub Transmission clutch no 3 64.51
33395-12021 sleeve Transmission hub no 3 58.27
33336-12061 5th gear 86.00
90364-28023 bearing, needle roller 18.86
33151-28020 retainer bearing rear 62.04
File Size: 94kb PDF
Download: http://RAV4World.com/tsb/TC001-01.pdf
R4W Comments:
is this a recall :roll:
