Hello,my name is Mario and live in Orlando FL, thanks for adding me to the forum, I just recently got a 02 Rav4, and was wondering if I am able to use 05 Lexus es 350 rims ? or what other rims can I use Toyota or otherwise ?any help will be greatly appreciated .. thanks in advance !!
Hi, Welcome to the world of Rav4.
Wheels are made up of these mission critical numbers:
-Diameter, Width
-Bolt Pattern
-C.B./Centerbore aka Hub Size
-Offset
Since youre going from Toyota to Toyota it's a safe bet. And this research confirms it in theory:
If you go advanced with modding, after my recent failure with small 5mm spacers I recommend doing all offsets, especially offsets under 25mm (1") by wheel choice instead of adding parts.
Please post pics once you get it done as a thanks.
Thanks for the reply, by chance any idea on which rims would fit without any modifications ? Other then Rav4s, or woukd newer Rav4s rims fit ?
I dont know, but probably a bunch of toyota wheels.
The wheels that fit must match the requirements listed above. You really should commit to learning the terms: Bolt pattern, offset, Diameter, width, Centerbore. It's definitely an exact science, not a guess and check thing. I can walk up to a wheel, flip it over, read the numbers on the back, and know if it will work for my car- and you can too :).
