For about three years now, I've been trying to find a problem on this 2014 rav4 and am stumped.
I'm not seeing anything that seems to be a danger so I've wanted to solve it on my own before bringing it to a dealer.
I'm at the point where I'm about to bring it in for an assessment but I'm not sure what they will find.
The grinding sounds like the brakes but it's not. That said, the rotors keep getting warped. I know it's the rotors because there is a ton of meat left on the pads and rotors but when I replace them, no more warbling when we hit the brakes.
The pads and the rotors are always nice and clean, no gouges, no nothing obvious.
After I change them, around five to six months later, the warbling starts then the grinding starts. The warbling is highly evident while at highway speeds which sometimes makes me wonder if it might just be an alignment issue but then there's the grinding.
You can hear it even as very slow speeds. I've tried putting more pressure on shorter stops as well as slow, gradual stops but the same grinding sounds. Since the car has 150K miles on it now, I just changed the front bearings thinking maybe when the front end is loading the bearings a little, the grinding is happening due to degrading bearings. No change.
When I change the pads and rotors, I really try to make sure everything is done right and that everything looks ok and it does.
It's the 4 cyl model, Limited edition. I' super stumped on this. What could the problem be?
