Gentlemen,
Please help me with this problem.
Car: 2002 Toyota RAV4 "L"
Major Fixes: ECU-resolder ; Fuel Pump Replacement; Fuel Injector Replacement
Minor Fixes: Idle Air Control Valve Cleaning w/ new gasket; MAF Sensor Cleaning
Most Recent Fix:Recently replaced old IAC gasket (which was ripped) with new gasket.
Symptom: Idle at cold start is around 1000 RPM. Idle once warm is around 0-200 rpm, does not stall.
Tried to take out fuses so on and so forth. Nothing yet.
Other issue: After an oil change w/ seafoam approx. 6 months ago my timing chain tensioner seems to have given way, now has rattle sound from chain hitting valve cover I think?
Do you think it's the timing chain tensioner giving me the bad idle? Please Help.
Thanks.
Jesse
Thanks.
Jesse
