Hi, I am not sure if anybody experience that the light / lamp behind the temperature selector got burn out?
Mine was on sometime and off once a while, not sure if the light bulb got burn out or the wire got lose, anyway to check it out or take out the panel to inspect?
This is for 07 RAV4, thanks
To get access to the HVAC panel, you need to remove the stereo head unit. Pop off the 2 side trim pieces (the right piece has the hazard flasher switch) and then there are 4 10mm bolts to remove and the head unit slides right out.
thanks for the video sharing, my light was in and out, not sure if the wire of that light bulb was lose or the bulb going to burn.
